Radiator temperatures
10 Feb 2007
Cumbria
What is the correct temperature for a normal domestic radiator, I was thinking about 50 degree so a hand can grasp it. Which would mean a flow temperature of 50 right?
The answer is the lowest that will provide enough heat in the room!
The maximum depends on the boiler type.
A non condensing boiler used to be designed for a flow of 82°C
A condensing boiler 75°C
But those are maximum temperatures. the boiler will be more efficient if the flow temperature is reduced below those maximum temperatures.
Better still with weather compensation.
Tony
