Radiator valve size interchangeability
7 Jan 2024
I'm wanting to swap around the sides of my TRV valve and Lockshield, but apart from them both being 15mm connections, are valve bodies generally universal/the same dimensions? I.e. will I have to play around with tail protrusion and inlet pipe dimensions.
The valves are Drayton eB valves and lockshields.
If they’re the same make, and often if they’re not, you’re usually ok swapping over. It’s when you get cheap Chinese valves where they can change just a fraction.
