Radiators constantly hot
14 Mar 2016
My house is too hot due to the central heating being on, even though the control unit for my Ideal logic 24 combi is set to the off position. I have changed the batteries to two new Duracell batteries and switched the boiler mode selector to hot water only. Ironically, the central heating is still on and, although the control programme is set between 17-19 degrees max (at different time zones) it is Varying between 20-23 degrees. I have powered it down at the fused spur and then turned the mode selector to the reset position and then on to hot water only. The problem still persists though at the moment I appear to only be able to control it by turning the boiler mode selector to the off position which, isn't practical with young grandchildren and young adults. Any suggestions on what I could do before calling a heating engineer?
retitled and moved to plumbing and heating
There is very little you can do, as the boiler needs looking at, and this task can only be performed by a gas registered engineer.
It sounds like you could have a divertor valve issue.
Thanks for replying. That sounds like it's not physically turning a valve from hot water to central heating. Would that cause my problem?
Yes, it and electrical controlled mechanical device that diverts between domestic hot water to central heating.
A heating engineer has called and said that it's two parts. One was leaking water and the part that turns the diverter valve had water in it. So the leak needs sorting and the other part needs replacing. He also said that my hot water is going into my radiators due to the fault, this is why they're getting hot. Even though the boiler is set to hot water only. I really appreciate your help, Thanks again.
Hopefully that's not quite what he said!
Hopefully he said that the heat was going into your radiators rather than the water.
