Hi everyone, first post. Moved into our new house a few weeks ago but now realising that the central heating system isn't working that well. Hubby's been trying to fix it but he's not making much progress and hates the thought of being ripped off by BG.
Thought I'd try you guys for some advice. Might be something simple or really expensive. I'll explain the setup and the problem ...
The flow and return circuits are 22mm. From the boiler, an equal tee has been used to split the feed for upstairs and downstairs – all 22mm. It’s the same for the return. The boiler is located upstairs.
There are ten radiators, five upstairs and five downstairs. Each radiator has an 8mm microbore feed-branch and return-branch with a distance of not more than 2 metres from the main 22mm branch.
There are no problems upstairs – all radiators are hot, so too is the 8mm feed and return. All upstairs radiators have a TRV. We’ve checked to make sure that the TRV arrow is pointing in the direction of flow.
All’s not so well downstairs. Again, the feed and return is 8mm microbore. All but one has a TRV. Again, we’ve checked to make sure that the arrow on the TRV is pointing in the direction of flow. However, on each radiator, the feed is hot - but the return is cold, or lukewarm at best. Only the top-half of the downstairs radiators gets hot. The bottom is lukewarm to warmish, but never hot. We've tried to balance the system - by opening the the tap-screw "thingie" at at opposite end of the TRV full for those radiators furthest from boiler, and almost closing those closest to the boiler. This helps a little, but not alot.
Thinking that it was a problem with the pump,hubby replaced it with a new Grundfos 15-60 and set the speed to III. We also pumped up the expansion tank to 1bar, which helped a little but didn’t last long. (Expansion tank shows 1 .. 1.5bar when the CH is running). The system water pressure is set to 1Bar, rising to 2Bar when the CH is running. The system is a Vokera Option.
Sorry to ramble; hope someone can offer some advice. A friend suggested a power-flush, but thought I'd seek help here first. Hopefully we don't need a new boiler
Thanks guys
Thanks guys
