Radiators get hot even when switch is on water only
16 Dec 2005
Lancashire
Switch is on water only but heating still comes on very hot,
despite being on minimum.Does any one have
any ideas what the problem could be?
weareleeds said:
We may be good but we ain't mind readers what blr is it what kind of system etc.etc.etc.
Many thanks for your reply
The boiler is a GLOW-WORM CAPRICORN 240/6 which rests behind the gas fire i.e. backboiler and its a gas fired system.
The problem started last week when one morning with both switches(heating and water) on the radiators did not heat up and only got hot water.
Then the following morning they started heating up but they heat up now even when the switch is on water only.
Many Thanks
andy said:
sticky 3port valve?
Any idea as to the cost of fixing this problem.
I have a back boiler gas fired system - GLOW-WORM CAPRICORN 240/6.
Thanks in advance
adcomarc said:
andy said:
sticky 3port valve?
Thanks in advance
find out if it is the 3port valve first... thats if you have a fully pumped system. if it is the valve, replace it
andy said:
adcomarc said:
andy said:
sticky 3port valve?
Thanks in advance
Thanks a lot for your advice Andy.Yes it is a fully pumped system,i will get the valve replaced.
Many thanks
