Most of my double panel radiators are hot [normal heat] around the sides and the top, leaving a large area cold or some are luke warm in a very large area in the centre. Two single panel radiators are heating as normal.
Had a pipe [outside] to the boiler repaired during the summer as it had burst.Plumber did not drain system down to do this but his mate did something in the loft before they started which seemed to be important before they could begin also at the same time had a valve replaced on boiler [oil fired] at top right as it was leaking [think this may be some type of pressure valve?]
Afterwards they bled some radiators as I have done now, no air just water.
Not blaming the plumber as he is a family friend, just wanting some advice and giving a bit of history.
Did not know rads were not heating correctly until now [winter]
Any help would be greatly appreciated.
