Radiators Hot when Hot Water On - 2 Way Motorised Valve
5 Jun 2015
Hampshire
For the past few days when the hot water clicks on the Radiators click on as well.
- I have the heating set to 'off' so I know it is not the thermostat.
- If set the radiators to off on the boiler then the hot water doesn't come on!?
I have a two port valve which from my reading will not be the problem?
Can anyone suggest what the root cause might be?
Could be good if you said what boiler you have and if you have a programmer.
Have a look at Boilers and Central Heating FAQ 10. This shows your valve and my give the answer to your problem.
Thanks. I wonder if part of the problem is the position of the black CH plastic valve? It was in the middle of the two so I moved it to the left - is this right?
