- Joined
- 25 Aug 2025
- Messages
- 10
- Reaction score
- 0
- Country
I have a gravity central heating system. Just moved in to house. Rafa were on when hot water came on. So I replaced the Honey Well power valve as I tried just the motor and still had the issue. Old 3 valve looked very worn.
I tried to refill the system from header tank but it would not completely refill, rads upstairs were not filling up but downstairs did. So back filled it from downstairs rad, drain valve. Bleed all rads upstairs and downstairs, water started going back in header tank so I guessed it was full. Then I found a split in copper pipe coming off header tank, so guessed that was why it was not filling up. Replace copper pipe. Started system back up and it did sound like it had a fair bit of air in system.
The strange thing now is rads are still getting hot when hot water is on, but what's really strange is the pipe off the powerhead valve to radiators doesn't get warm until it's been running for a while but rads get very hot instantly, like the hot water is finding another way to the rads! How can this be possible?
System is running pretty quietly at the moment but still rads coming on. Could I have a blockage somewhere, I can't figure it out. I ran out of time so need to go back to it this weekend. Thinking of draining the system again and letting header tank refill it?
It's just so strange how the rads get red hot when only water should be on and the pipe out of valve to rads doesn't get hot, just warm.
I check the valve operated correctly with my wiring and it all look correct, hot water, central heating or both open. Motor had exactly same colour wires and same model so I know that's all correct.
Would really appreciate any advice and if anyone has seen this before?
Many thanks
Simon
Many thanks
Simon
