radiators
30 Nov 2010
hi my downstairs rads all work fine and 2 rads upstairs are constantly cold but the other 5 upstairs are working does anyone know what i should do to get the 2 working. I have bleed all rads when heating is on and all have water coming out.???
Turn off all the radiators downstairs for 15minutes see if they heat up. If not turn the remaining radiators off upstairs leaving only the 2 not working on. The pump should force the water to theses radiators. If not you may have a blocked pipe. Usually does the trick though.
