Hi All
I replaced my central heating with a Vaillant ecoTEC combi boiler that is feeding 4 radiators downstairs and 5 upstairs (3 norm. size bedrooms + 1 bath + 1 toilet). The problem is that the downstairs radiators don't work properly; two of them get only lukewarm while the other two are just cold. All the upstairs ones work perfectly well. I have done the bleeding of all the radiators and apparently there is no air in the system. The pressure on the boiler's pressure gauge is also fine + there are absolutely no problems with the hot water upstairs in the bath and downstairs in the kitchen.
The boiler is fitted in the kitchen downstairs and I believe the problem is the way the plumber (whom I can't seem to find now) has connected the FLOW pipe; the FLOW pipe comes out of the combi and then there is a T-junction that distributes the heated FLOW water for upstairs and downstairs radiators. However, the piping from the T-junction to the first downstairs radiator is at least 5 times longer as compared to the first radiator upstairs. I have tried turning off all upstairs radiators; this makes the 2 downstairs rads work fine (almost) but the rest of the 2 get just barely warm. However, the moment I slowly turn on the upstairs ones, the downstairs rads gradually get back to the previous behavior.
Any advice from you guys will be greatly appreciated.
Many thanks.
Imran
Many thanks.
Imran
