Hi all. New here and I'm having difficulty explaining what a neighbour has done to their house - I'm trying to find information online about it, but failing. Hopefully someone knows the terminology I'm grasping at.
Essentially, all the houses on the street are the same detached construction, with trussed roof timbers. We've previously looked at a loft conversion, but have been a little put-off by how much usable space will be created and the extra cost of reinforcing the roof when the timber construction is changed.
Our neighbour appears to have increased the height of the ridge and then built a half storey on the back i.e. not new regular windows, but velux windows over 4 ft of new brick work. The house appearance from the front is unaffected, but I'm guessing the usable space at the rear is significantly increased. I've not had chance to talk to them about it yet as they are on holiday while the work is completed, but I understand they are creating two new bedrooms with a shared ensuite.
I'm wondering if there is a special term for this type of conversion. I'm guessing it is significantly more expensive than a regular truss loft conversion (even my dull witted mind can understand the difficulties of keeping a roof up while you brick in more wall
