Rangemaster ovens not working
13 Nov 2008
Avon
I have a Leisure Rangemaster 110 electric model.
Both cookers have been working fine no problem up untill the electrician turned the mains off a few times whilst doing some electrical work in the house.
The clock shows 0:00 and auto to the left.
Turning the cooker socket off for 5 minutes then on again shows the same display and i am sure in the past the 0:00 used to flash so you could set the clock.
Pressing the - & + buttons have no affect.
Neither of the ovens work,But the hob & grill work fine.
Does it sound like the clock is stuck in auto mode and if so is there a fix without replacing the clock if so please advise.
You need to turn auto off and set the clock for it to work.
How do you turn the auto off ?
Pressing the reset button does nothing.
Have u got the manual or tried google for it. Normally it's the time button then plus or minus to set the clock.
There are 6 buttons.
I have pressed the 2 buttons starting from the left then pressed & released the + button but no joy.
If the clock is duff how can i bypass it as i dont use it anyway.
I think the power goes into the clock but because its stuck on auto no pwer is then coming out.
If i can find out where the power in & power out wire is i should be ok to go ?
Cook period and stop time have u pressed them and plus minus.
I pressed minute timer & cook period together and held wilst a press and release of the + button
Hello,
I have just spent nearly £200 on having my clock fixed. Press and hold 'cook period' & 'stop time' while using + or - buttons to set to the correct time. The guy literally fixed it in 30 seconds. Don't make the same mistake as me.
