hi
boiler works fine until reaching selected water temp. [ c/h mode ] but then continues to cycle until room therm kicks in and switches it off. The anticycle device has stop working. Can you help....
Dhw works fine. ie. boiler fires modulates ect. as it should.
thanks.
Thought about it ...then ignored it....but now when c/h water temp is reached. A relay starts chattering on pcb, it stops if i move the c/h potentiometer. While doing this i noticed the boiler has ceased to modulate when potentiometer turned up. Through doing a bit of reading + multi meter i found that the c/h thermister is not working...awaiting new censor now.
My question , Could that censor be the cause of my boiler's cycling problem and if so will i now need to replace the relay on the pcb . It has scorched its cover...
thanks.
