ravenheat boiler ls80 little star (problem)
23 Oct 2010
Yorkshire
hey, hope someone can help my boiler is 6yr old and is working but when the central heating reaches the room state temp. the boiler shuts off as normal but then just keep going through it's start up ignition procedure all the time?
had a ch/dhw sensor fitted last year because the dhw stopped working bought a sensor for the ch but still the same problem please advise thanks deano..
yep nath it completely starts up again not allowing the boiler to cool down at all got to be some kind of thermostat problem surely??
We are having the same problem with our Ravenheat white star 80t. Did you ever find the problem with the boiler switching itself on and off once it had reached temperature?
I have had advice that Ravenheats are bad, but i would prefer to fix it if i can. The dhw is working fine, the problem only occurs with the ch. Cheers
