Hi all
I am not getting much joy with my 2 year old Ravenheat HE85T combi boiler. Ravenheat say its similar to CSI85T.
I've recently had the issue of DHW cutting out randomly in shower and changed the CH thermistor (dry clip on type) which solved the issue.
Then there was a leak from the diverter valve. Was suggested that the system could be dirty, so the system was thoroughly mains flushed, fixed magnaclean, replaced diverter valve, added inhibitor and there is no leak now..
Another issue that now I've been seeing is that sometimes when the BOILER is COLD (and NOT ALREADY ON for CH), and we open the DHW tap in kitchen sink, the boiler does not seem to do anything. No fan, no pump, no noise etc as if there is no demand for CH or DHW.
This is remedied by:
1. If I close the tap and open it again the boiler starts working as usual in an attempt or two.
2. If I switch the boiler ON/ OFF through the instrument panel, it starts working as usual.
The CH comes ON when demanded without a beat (touchwood).
Previously I thought it could be due to diverter valve but a few days after replacing the diverter valve, it again failed to do anything today when the DHW was called for..
One thing to note is that we did not see this issue of DHW not coming with the CH ON. But then the boiler with fan and pump are already ON for CH, so we get instant hot water..
I am thinking it could become a bigger issue come summers as CH would be OFF, so the only demand from a COLD boiler would be DHW.
Any ideas?
Thanks in advance..
Any ideas?
Thanks in advance..
