Hi, Just after any advice in case someone has seen this before !
I have a Ravenheat "Medium Range" boiler, not defo sure of model (as at work)
but don't think that will matter much ! The boiler has been serviced regularly and has worked flawlessly for 5 years.
This is what is happening now - any thoughts as my excellent plumber is pretty flumoxed at the mo'
I noticed the problem when on Auto the boiler did not light and the 'Red Light' indicating no flame came on. If you turn the boiler off and back on, then, on average, after about the 5th attempt the boiler will light and will function seemingly perfectly happily until it's switched off due to the timer or me. Then the same scenario is conducted again, switched on/off several times and then it will fire up again.
Any thoughts/advice I can pass on to my plumber most appreciated....
