Can some one help with a little boiler problem I have.
Being the middle of summer the roomstat is set so as the heating will not come on and also the boiler switch is set to hot water only.
Every now and again it appears that the pump starts up and water circulates through the central heating (I can hear it in the radiator).
I sort of thought this might be in built design to make sure there is no build up of sludge anywhere if the heating is off for a long period (I thought it was logical
Today the heating actually came on, even though the roomstat is set very low and the heating/hot water is set to hot water only.
The display which normally indicates the temp was blank. The burner light was illuminated though.
I pushed the reset which didn't do anything. I had to turn the boiler off and on again and all was well again..
With thanks.....Phil..
