Hi I have been having this issue for some time - The boiler works fine but when drawing hot water it gets up to temp then the flame cuts out and the water temp drops (Not good when your in the shower)- after a few seconds the flame come back on and the temp rises again, If I have the DHW potentiometer set low the flame stays on but the water temp is low, if I turn the DHW potentiometer up the flame carries on but then cuts out again. I have replaced the diaphragm,diverter valve, and water pressure switch, also DHW sensor and CH sensor but issue continues. The Diverter valve and water pressure switch are working ok and the potentiometer modulates the gas ok and works at the lower setting so I think there must be an overheat sensor somewhere that I've not found - can anyone help identify the issue and let me know how to resolve? any suggestions gratefully received.
