Slugbabydotcom said:Are you 'FCA', and your last two phone number digits '61'? If so, I think I'll give you a bell on Monday! Failing that, I'm not sure if Ravenheat will help me when I ask for 'slugbabydotcom'
Yep that's me. You can catch me in on that number between 11 and 12.30 ish
OK, thanks for the confirmation.
I've been experimenting with the HW temperature control on the front of the boiler (instead of leaving at max). It's now at the 12:30 position, about half way between the tap and the dot. Running the hot water is now much better - it doesn't cut out, although I don't think it's coming out of the tap quite as hot. Before I replaced the HW and CH sensors, messing around with this dial didn't stop the cutting out at all.
So... it's working better, but I don't think it's 100%. Surely I should be able to set the dial to whatever I want? Cutting out can't be normal! And the boiler used to work fine with it on max.
I'll see how I get on today and tomorrow, but I think I'll give you a bell on Tuesday. Cheers!
