I got a new outdoor installation fitted a week ago with the main CU getting its seperate supply from the meter keeping the house and outdoor seperate.
Today I used power from one of the sockets and I went back tonight and went to switch the light on and no power. The Incomming RCCB was tripped.
What would cause it to trip?
TT setup is as follows:
I was using the power from CU3 earlier that day and none of the mcb's in CU2+3 were tripped, just CU1.
Is it likely that there wasn't enough power since the socket mcb in CU3 didn't trip for overload which I was using?
The Cable from CU1 - 2 - 3 is a min of 16mm which was fitted so that future electric installations could be fitted with no need for changing the cable.
The installation was tested as I needed the paperwork.
For a new installation its not a good start if the Main switch trips on first use.
Cheers for any help.[/img]
