Realising water pressure
16 Nov 2008
Lancashire
Hello hope you can help me I have a main 24HE combi boiler fitted only 2 years old working just fine but noticed the central heating system pressure gauge located on the front facia is showing nearly 3 bar was wondering if there is a way of reducing this down to a more comfortable 1-2 bar. Thanking you all in advance Allan
Drain some water out of the heating system via a drain off point under a radiator.
Make sure the filling loop is fully closed and/or removed.
You should really be looking into why its increased!
Do you remove the filling loop in accordance with the Water Regulations?
You can bleed water out of a radiator to reduce the pressure, about 2-3 litres.
Tony
Thanks for the quick reply will try draining out through radiator.Filling loop as always been attached since the day fitted?? i am sure both valves are turned off but will dusconnect loop to check valves are fully closed.
Once again thank you Allan
