    Dismiss Notice
Reducing a large / deep inspection chamber for vehicle traffic
Discussion in 'Building' started by VWP, 27 Jun 2020.
  1. VWP
    VWP
    27 Jun 2020
    2
    Thanks Received:
    Country:
    Hi All
    I have a 5 ft deep brick inspection chamber on my drive.
    Its 1.2m x 800 ish
    I am going to reduce it by spanning the 800 width with one of the below options
    1 - several 6x4 concrete lintels
    2 - several small steel RSJ's
    3 - shutter it, add rebar and pour an 8 inch deep slab
    4 - 10 mm steel road plate
    This will see vehicle traffic as its on my drive
    anyone got any recommendations?
    anyone done it
    i cant find a reducing slab thats not a fortune
    cheers folks
  2. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,182
    Thanks Received:
    1,679
    Northamptonshire
    Country:
    Does the chamber just take the waste from your house? I'd hazard a guess though, given the size, it's a shared (public) sewer.
    If the chamber is on a shared sewer then it's the Water Co's asset, you'll need their permission, carry out the work to their specification, and you possibly may need to use one of their Approved Contractor to make any alterations to it.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. JohnD
    JohnD
    15 Nov 2005
    71,049
    Thanks Received:
    4,025
    Crossgates
    Country:
    Cook Islands
    what sort of vehicles will be driving on it?
    What is the existing lid?
    Photos inside and out will help.
    • Thanks Thanks x 1
  5. VWP
    VWP
    27 Jun 2020
    2
    Thanks Received:
    Country:
    Just takes our waste
    no idea why its so deep.
    house is 1910.
    had a ( broken ) sandstone flag over one half and a cast lid on the other
    will have my t5 vw van on it
    will be getting block paved and a recessed block paved lid on once reduced
  6. Sponsored Links
  7. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,182
    Thanks Received:
    1,679
    Northamptonshire
    Country:
    Traditional method was to corbel the brickwork, later methods were to cast an in situ slab on top of 9" engineering brickwork. I'd go for the concrete slab, it should last longer than steel in that environment.
    • Thanks Thanks x 1
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
