Having read some of the other posts from a couple of years ago it looks like the only thing to remember is to bleed the rads starting from the downstairs and working up. Hope its that simple!
don`t even need to do in that order with sealed but it helps to have someone topping up while you bleed And your`e supposed to disconnect the filling loop after
