Regrouting Porcelain Patio
30 Jun 2005
Need some advice on best tool to use to remove old grout from porcelain patio. The joints are about 5mm. The area is around 60sq m.
Any advice appreciated
Multi tool will diamond grout removal tool try first. Vacuum as you go.
If that's too difficult then disc cutter and except any minor damage caused.
That's how id approach it but maybe others may have better ideas
Thanks Wayners. Was thinking that that was the best way to go . Maybe using a grout rake attached to 4 inch grinder? Not sure I can find one less than 5mm though
