Can anyone help? I have a Dado rail - grab adhesived on all the way through my hall stairs & landing. Dumb idea, I know, but back in the early 90's when I had just discovered No-Nails I fixed this dust collector rail on with BOTH screws & No-Nails !!
It has to come off because it is a large ugly section and looks quite dated. So while preparing for decorating I wonder what is the best and least destructive way to remove it? The screws are easy. Then I would think a sharp tap on the top, downwards, might break the seal and bring paint with it where glued. However, if I decide to lever it off, I may well bring, in a 1930's house with crumbly plaster, a sizeable part of the wall away.
I have experimented with a tiny section where least visible, using a decorators scraper & hammer to gently prise it away, that brought all the layers of paint with it down to skim plaster coat. Would probably fill quite easily afterwards though.
I had considered using a sharp knife along the upper & lower edges of the rail to cut at least through the paint layers and hope that any damage might be confined within these two cut lines.
Any suggestions please?
