    Dismiss Notice
removing grout from tiles
Discussion in 'Decorating and Painting' started by shakil, 14 Jan 2004.
  1. shakil
    shakil
    14 Jan 2004
    2
    Thanks Received:
    Country:
    Hi, Does anybody know, how to remove dried out grout from wall tiles? Thanks
  2. Sponsored Links
  3. masona
    masona
    5 Jan 2003
    12,885
    Thanks Received:
    125
    Essex
    Country:
    For cutting away old grout prior to re-grouting.
    [​IMG][​IMG]
    Available from most diy superstore’s,the picture above is from Screwfix.
  4. renovator
    renovator
    7 Jan 2004
    81
    Thanks Received:
    Country:
    do you mean clearing out old grout in preparation for new grout, if so see masona's reply.
    or do you mean cleaning the surface of ceramic tiles after grouting?
  5. shakil
    shakil
    14 Jan 2004
    2
    Thanks Received:
    Country:
    Hi, someone did some grouting for me but has left a thin layer of grout on the surface of ceramic tiles. And I wanted to remove this.
    Thanks for your help..
  6. masona
    masona
    5 Jan 2003
    12,885
    Thanks Received:
    125
    Essex
    Country:
    Sorry,I mis-read your post,
    I find it easier to use a old credit card (your partner credit card will do ;)) and scrape it off then finish off with wall tiles polish.
  7. renovator
    renovator
    7 Jan 2004
    81
    Thanks Received:
    Country:
    another neat trick is to thinly spread grout onto a piece of old towelling and set aside to dry.
    when dry roll it up to crack the grout and rub this over the tile surface, this will help polish the grout from the tile surface.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
