Rendering internally but which lime to use?
14 Oct 2008
Surrey
Because I am fitting a woodburning stove onto the hearth in my 1930's semi it seems the only surefire way to ensure the chimney breast surface doesn't blow/ crack or fall off is to have it rendered with a sand/ cement and lime mix.
I assume 2 coats will be necessary and I need to add lime, but which one? Hydraulic, non-hydraulic, NHL2, 3.5, 5.....................help me I'm suffering from lime overload!
How disappointed am I?............all you whizzkid plasterer's and no-one answers me question!
So, for the sake of anyone else who wants to know the answer, here is what I believe it to be:
If you are using cement in the render, you must use HYDRATED lime.
For extra info, I was going to 2 coat render my chimney breast cos I'm putting in a woodburner stove n only render will stay stuck to the 1930's bricks unless you want to buy super expensive vitcast heatproof plaster
