Hi Guys,
I am renovating a house and the old boiler, hot water tank, everything has been removed. I am starting from scratch. I require two showers to be run at the same time. The heating will be underfloor.
I have spoken to a few plumbers and have received pointless answers such as "why would you want to run two showers at once?" "leave it 2 years and you'll be glad to get away from your wife" etc.... No one has actually said how to achieve this.
I have ruled out a combi boiler (not enough flow), an unvented system (same problem), and by default have been left with storing a lot of water via a vented system. So... would this work:
Regular boiler https://www.plumbnation.co.uk/site/vaillant-ecotec-plus-430-regular-natural-gas-boiler-erp/
Large hot water tank (vented in the loft) https://www.plumbnation.co.uk/site/discount-copper-vented-indirect-cylinders/
Large cold water tank (stored in the loft) http://www.screwfix.com/p/polytank-cold-water-tank-50gallon-uk-1190-x-610-x-500mm/10134
3 bar (40l/min) Pump to suck the water from these tanks http://www.plumbworld.co.uk/stuart-turner-monsoon-30-bar-2388-18611
The cold water tank will just feed the showers, the taps will be mains pressure.
Am I along the right lines or totally wrong about this?
Thanks,
Thanks,
