- Joined
- 16 Nov 2022
- Messages
- 11
- Reaction score
- 3
- Country
I have a Vaillant Ecotec plus 831 with a Danfoss TP5.
The electrical connections are via a five core cable. I believe three
(live netural and earth are mains supply and the other two to Danfoss)
I want to wire in a Vaillant 380f wireless and believe that is simple -
2 wires from EBUS to new unit.
The danfoss is connected to the 230v purple RT and mains supply terminal in the boiler.
Two questions. Can I simply remove the the two cables connected to the Danfoss from the purple RT and live block
and connect them to the eBus and then connect the new receiver where the danfoss is now? Or will this risk induced current?
Ideally I would like to place the receiver/sender where the TP5 is now
If not, do I just run two connectors to the ebus and then disconnect the danfoss or leave it alone.
Obviously i would need to reinstall the link cable to make ebus work.
thanks in advance
thanks in advance
