Replaced chaffoteaux for Potterton Gold
23 May 2006
Southampton
Have last week replaced a Chaffoteaux Celtic balanced vertical flue combi after 18 years hard labour with a Potterton Gold 28HE combi.
I have been amazed at these Chaff's. This one has been installed in a one bed flat with numerous changes of tenants. Main problem with it was the pilot light kept blowing out with the wind, as it was an attic flat, prone to this problem. It was still working when we ripped its heart out (pump), it was just getting too noisy when demand for hot water.
Still more to the point, can anyone advise if they have experienced any inherent problems with the Potterton Gold I have put in. Tips on maintenance etc as I intend to keep this one going for hopefully the same amount of time :shock: :!:
Any comments much appreciated.
Make sure the system water is scrupulously clean and properly inhibited.
Contaminents in the system water (eg mineral oils from new radiators) can seriously degrade the O rings in the main heat exchanger. Once they fail a new heat exchanger will be required.
Check the 5 year warranty - most of these extended warranties do not cover installation faults or poor system water quality ie scale and sludge.
What's wrong with new 'O' rings?
3 years warranty on gold.
Many of the O ring compounds used in boilers are very intolerant to mineral oils (EPDM, Butyl) - hence the amount of leaks and sticking diverter valves we see.
There are about a dozen O rings used inside the plastic Giannoni heat exchangers - AFAIK they have only been on the market for 3 years ie not very long. The normal failure mode I find for contaminated O rings is either swelling (especially on sticking diverters) or compression set (embritlement).
Is the 3 year warranty subject to full service history, benchmark and a water sample? Some manufacturers (eg Heatline/Halstead) say they will honour the warranty regardless of the quality of the installation (I don't believe them) - they can just drag out the job and p**s off the customer.
tryitandsee said:
Still more to the point, can anyone advise if they have experienced any inherent problems with the Potterton Gold I have put in. Tips on maintenance etc as I intend to keep this one going for hopefully the same amount of time :shock: :!: Any comments much appreciated.
:lol: :lol: :lol: :lol:
Interesting replies. We rather rushed the clean out of the existing pipework and rads, at my cost in the future I suspect. Still, quite impressed with the simplicity of all the main bits for access etc.. Time will tell.
Gasguru. It appears all plastic washers and o rings degrade pretty quickly. Had to change diaphragm on a torbec valve after one year, rubber was perished, black liquid dripping all over carpet and staining as I disposed of it. Wife went mad, not even a thank you for mending the noisy valve :roll:
