Could someone offer me some advice please. I don't intend doing anything myself but would like to understand what will be required before I get someone to have a look.
One of the cavities in the oven has packed in and as it's over 10 years old it's time for a replacement.
The one I'm looking at is a Neff U14M42N3GB and has total connected load 5.7Kw
The current set up is 32amp MCB, 6mm flat T&E, isolation switch above worktop, outlet below and a flex cable to hob and to oven.
The hob (which is not to be replaced) is 6.4Kw and the existing oven is 4.3Kw. I've never had a problem with anything, even at Christmas with everthing going full blast.
Will anything need upgrading or will the present set up be ok with the new oven being connected in place of the old one, considering the extra 1.4Kw load.
