Sorry about this, I mis-posted it under the wrong forum:-
I am about to replace a floor in an 1890's terraced house. The undersite is solid clay. While I appreciate that up to 18" should be removed to be ideal, what is the depth of slab that building control will accept? I plan to use a good levelling layer of sharp sand beneath the 1200 DPM on the clay, I then intend to use 70 -75mm of insulation. If I finish with a 4" polished concrete slab, I'm hoping to get away with only going down about 10". I shall have an insulating layer around the edge of the slab and be sealing the joint to wall with synthaprufe.
TIA
TIA
