Replacement Crittall
18 Jan 2023
Hello
I have a 1960's bungalow with steel Crittall windows which I am thinking about replacing with modern plastic double glazed units. My concern about this is that windows on the gable end walls have a soldier course of bricks over the window but no lintel. It appears that the windows are acting as a structural element to support the brickwork above them. I have had estimates from window installers but they seem to think this is not a problem.
So my question is - are they correct. Can the windows be replaced without putting in some sort of support for the gable wall above them?
It needs supporting if no lintel.
DG firms just don't want the hassle!
Are you using national companies or local established fitters? A local recommended company with a reputation to maintain should give you advice.
I briefly worked for a national company and my experience was that many are on a par with used car salesmen and estate agents!
Thanks for the reply. I suspected that was the case so thanks for the confirmation.
Typical bot chatgpt reply if ever there was one
Edit: The poster or Bot seems to have deleted it's post!
