Replacement Screen Channel
12 Dec 2009
Devon
Does anyone know of a supplier of replacement channels for bath panel screens?
I'm in the middle of renovating a bathroom in which the bath was replaced but the client wanted to keep the screen. I damaged the channel taking it off the wall as it was stuck on like a goodun. I wasn't too fussed as I assumed it would be easy to find a replacement on the internet.
We all know what assumptions are.....
Any help would be appreciated
Thanks PrenticeBoyofDerry, I'm getting closer.
The channel I'm replacing isn't a U - its more of a D with its arms up (???) - a kinda D= shape with the glass slipping into the = bit of that.... (if you understand that then you're a better man that I am).
The U channels may just work though so thanks for your help
I may be looking for a custom size screen when I refurb and I found there are a lot of companies that build custom screens in the uk rather than buying in from abroad. It might be worth a search for Custom shower screens and see if anyone can supply something that would fit your screen from stock.
