Replacement sun room
13 Jul 2009
Hi everyone,
Some advice please, I am replacing my sun room and would like some construction advice.
I am intending to form a stud frame from 4x2 CLS and will be using reclaimed upvc reclaimed window frames and cladding the exterior in 6x1 cladding with insulation on the inside and plasterboard.
The question is how should I position the window frames, should they fixed flush to the inside of the framework or set back from the front edge and inch or so. The exterior cill boards will be plastic and I realise that they need to be set so they cover the external cladding.
The size is approx 3m x 3m with a flat roof with a 2inch fall.
So any advice would be most useful.
Many thanks.
