Replacing a mechanical timer. Wiring confusion.
15 Feb 2011
I bought a wireless timer/thermostat to replace a crappy mechanical timer. The old mechanical timer has three connections, live in, live out and neutral. The receiver of the new digital timer has four, live, neutral, 1 & 2.
Any assistance appreciated.
Craig.
The old mechanical timer is an eclipse ET16A, the new timer is a towerstat remote Eco ET4RF. The boiler is a glowworm flexicom 35 cx.
To be on the safe side, I would wire the receiver directly into the boiler.
TURN POWER OFF TO BOILER!!
First, remove the electrical cartridge as in 11.1 in the boiler manual.
Remove the wiring for the old programmer/stat from elec. cartridge.
Connect a 240v mains supply to the L & N terminals on the stat receiver.
See diagram 11.2 in manual.
Under the words 'Installer Interface', there are 3 connections underneath on the left labelled 24V - Ebus - 0V
Connect a wire from 1 on stat receiver to 24V in boiler elec. cartridge
Connect a wire from 2 on stat receiver to 0V in boiler elec. cartridge
put all back together. Job done!
Thanks whitespirit66, brilliant instructions. Did it last night as soon as I read your post.
Job done.
Thanks so much.
