Hi there. I'm trying to replace my ancient Switchmaster thermostat with no luck.
Currently it is wired so:
Live (Red) into terminal 3
Neutral (Black) into terminal 1
Earth (Yellow/green) into the Earth terminal.
Terminal 2 is empty.
I've now bought a cheap Sunvic stat because it was the only one I could find for two wire installation. The last one I bought was asking for Live, neutral and switched live. As I only have Live and neutral coming out of the wall (discounting earth) I figured this was wrong and went to buy the Sunvic instead.
So, the Sunvic has three terminals; 1, 2 and 3. The instructions state:
COM 2, DEM 1, SAT 3, NEUT n/a. If neutral isn't required, what do I do with the black wire? Basically I just need to know where I put the red, black and yellow wires! I assume red goes into COM(2) so should black go into DEM(1) or SAT(3)? And where should the earth go? Any help greatly appreciated! I thought it would be a case of taking the old one off and replacing like for like (as you would with sockets and switches) but not so! Each stat appears to be totally different.
