Replacing a thermostat receiver and battery operated room thermostat
28 Apr 2008
Isle of Wight
I want to change my old Honeywell HC60NG receiver and the room stat
HCW
80 as its working intermittently even after changing batteries. I don't want a fancy £300 job just a basic one that does the work this one has done for years.
20261115_105208.jpg It has 5 connections from one cable going in the back, is that correct or are some wires from the conduit underneath? What are the 2 wires not E,N or L and will it be straight forward to connect a newer receiver unit and room stat. I have looked at newer ones and they all seem to have only 4 connections? the new ones don't require an earth, but the diagrams are black and white and just want some advice please. Many thanks.
There is another post about the same thing here may be worth looking at.
The Honeywell unit was designed for non modulating boilers, question one must be is your boiler non modulating i.e. not a condensing boiler?
Likely the Drayton Wiser would work well and allow latter increased control, but so would Tado, Hive, Evohome and many others, so it depends what you want.
Linking the two wires in red circle
put both in the same terminal will likely mean the boiler will run, but as to getting the home too hot, depends on if you have TRVs fitted and if they are set up. So need to tell us a little more about what you have.
Hi ericmark,
The boiler I have is a Valaint eco TEC plus, yes i do have TRVs fitted, this is a condensing boiler Iam sure.
HCW
Typical wiring therefore most will be easy to fit, Something like a Hive would do.
Using the one channel option the two wires in red circle go to 1 and 3, Hive and Wiser both use same back plate, so the difference is down to how the TRV heads work once you add them, I prefer the Wiser, but up to you, the wall thermostats on their own work the same, it is when adding electronic TRV heads when Wiser works better.
You could opt for Vaillant wireless or Glowworm (same company) that use ebus for better modulation or just on/off and vast majority will cover that.
ericmark thank you taking the time to post the drawings, much appreciated. Just one more thing, we never used to have a wall thermostat at all and when we moved here the TRVs were already fitted, we only had the room thermostat fitted on advice from the gas fitter when he serviced the boiler, took his advice, should I have left it as it was do you think?
There is only a need for a wall thermostat when the TRVs are on an outside wall. If on the outside wall, the cold from the wall can cause the TRVs to fire the boiler too early. This is assuming using something like Drayton Wiser or Honeywell EvoHome where the TRVs link direct to the hub, which in turn connects to boiler.
If the TRV heads don't connect to boiler other than with the water, then that's another story.
The point is that Autumn and Spring, the wall may be cold enough to start the central heating, when the room is still warm enough, however once the thermals are established then circulation3.jpgit will not matter, so setting the temperature a little on the low side Autumn and Spring will in the main do the same thing.
I know Kasa TRV heads can be linked to either a sensor or a wall thermostat, latter has a control panel so you can see the temperature, 1794838511535.png1794838444586.png I was going to use Kasa, and got one TRV head, but the wall thermostat shown does not connect to boiler, I have hunted and the hard wired thermostat seems to have gone, it does have some features like open door/window detect 1794838896500.png but I realised I had made an error, and moved to Drayton Wiser, if one with the app puts a TRV and wall thermostat in the same room, they will it seems work as one unit, to get around the cold wall problem, however I have not used the feature, the Wiser TRV was opposite corner of house to boiler, so needed a socket adaptor to relay the signal (it uses zigbee) it does not seem to connect to non Wiser zigbee, maybe that's me, not setting it up correctly?
However with both our bedrooms used at the same time, only the coldest needs to use a linked TRV head, so my head is eQ-3 bluetooth I got 5 and £15 each in 2019, since brexit price has gone up, but other makes have become cheaper that use wifi.
If the TRV is not linked, setting it to 24ºC rather than 22ºC set on wall thermostat does not really matter, and in other rooms setting to 14ºC can also result in not heating unused rooms.
This is where the design of the home, and your life style starts to matter, if when you come home, you sit in living room from 6 pm to 7 pm then start cooking dinner, one can set the living room to come on maybe 15 minutes before the kitchen, so living room heats up faster, mother house I found set to 21ºC at 7 am it was nearly 11 am before at 21ºC, so I cheated, set to 23ºC at 7am and 21ºC at 8 am and up to temperature by 8 am.
This sort of thing is trial and error, set the kitchen to run 20 minutes after living room, and the boiler may have cut out by then, so it depends on your set up, what works for me may not work for you.
I see the Wiser TRV is claimed to work out how long it takes to heat a room, so it decides when to turn on, you set time and temperature you want room, it decides how long before that time it needs to turn on.
However my Nest Gen 3 was claimed to be a learning thermostat, and it got it all wrong. Same with Nest and geo-fencing, it would turn off OK, but too late turning back on again.
The other problem is makes like Tado and Hive make a range of thermostats, and it's easy to say Hive does this or that, then find out your version does not have that option.
