I'm starting to think about replacing my boiler and am hoping for some confirmation/advice.
I presently have an old Netaheat with a hot water cylinder and 2 cold water tanks - 1 for the hot water cylinder and 1 for the cold water supply in the bathroom (I think). I also have 4 radiators, in a ground floor flat of 4 rooms, one of which is the bathroom.
Anyway, I am considering a Potterton Gold C24 HE, because it was recommended by WHICH, and am hoping that at the same time as the work is being done, the cold water supply to the bathroom can be changed to a mains supply. This is because the pressure from the mixer shower at the moment is pretty low, due to the cold water tank (and the hot water cylinder) being only a few feet above the level of the shower head. There are also about a dozen separate spray nozzles which don't really chuck out water as powerfully as they could.
So, if I did the above, would I notice the difference in the pressure of the shower or would I need to do something else ? Would a bigger bore hose make a difference ?
Finally, what sort of price should I expect for the boiler plus installation, etc - £3000 ?
Thanks for any replies.
