Replacing double oven
28 Jul 2013
Lincolnshire
Hi, I'm replacing a double oven, from a different manufacturer than the original, and have the connections shown below
Could anybody tell me am I correct in thinking that I use the furthest left L and N terminals?
Apologies if this seems obvious but I just wanted to double check.
The wiring diagram, shows that for 230v, there are some bridges/links that need to be fitted for the L and N connections - which have been fitted on your oven already by the manufacturer.
So you can just connect your suitable sized T&E cable to the L connection at the easiest location, in my opinion - screw #2 - labelled L (counting from the from the left) and N connection can go to screw #5 - labelled N.
The last screw #6 is for your sleeved earth connection.
Hope this helps.
