Replacing felt roof with bitumen corrugated sheets
17 Jun 2010
Sussex
I had someone replace the felt on my shed roof only two years ago and it couldn't have been done properly as it is now leaking at the joins very badly and the wood on the roof under the felt is soaked. I am thinking of redoing the roof with bitumen corrugated sheets so they may last longer than felt. I am going to do it myself but has anyone used this before and any tips please? The shed is about 8 x 10, stand alone, do I need to remove the felt beforehand or can I just put the corrugated sheets over the felt to save some work/time? Thank you for any assistance anyone can give.
shed felt is rubbish and will not last if you use the next grade up you should get ten years out of it
Did he overlap the felt correctly ie the joints are horizontal and the bottom edge of one sheet over laps the top edge of the adjoining sheet (if not rain water will run between the two sheets and into the shed) - I have seen it done incorrectly!!
Has the shed roof been walked on - this can cause damage to the felt?
As mentioned, try to use a quality felt. Done properly and it should last for years.
Thank you both for your replies. No, the roof has not been walked on but I actually purchased the felt and got the better grade type thinking it would last longer. Yesterday I got the ladders out and having a quick look, it seems that the joins although overlapping, don't have any adhesive on them and yet I gave the person who did the work the full can of adhesive I had purchased. Yes, I know, well and truly taken in. I thought if I used the bitumen corrugated sheets it would maybe be easier to fit and not need replacing for years and years and as I now don't trust anyone else to do the work, would be easier for me to do that than to try to lift new felt onto the roof.
