D
Deleted member 107080
I need to replace the expansion tank on the hot water side of heating system. The cylnder is a Tribune HE. Clearly I need to turn off the cold water feed however I note that there is a drain tap at the bottom of the cold water inlet pipe going into the cyclinder. Do I need to drain the tank completely before removing the expansion tank?
Thanks in advance.
Thanks in advance.
