replacing radiator valves - system off, yes or no?
23 Feb 2006
London
i hope this is a simple question.
do i have to drain the heating system to replace both in and out radiator valves.
i am attempting to replace them with more decorative ones.
if i do not have to drain the system, then i am tempted to do this. what should i expect. some excess water that will stop ?
thanks
glen
Yes you will have to drain down that 'drop' if it is a downstairs rad.
Look in the 'look here first' topic above for advice to refill. :D
hi Bahco, what do you mean, "you would have to drain down that 'drop'.."
the radiator is upstairs anyway
thank you
Assuming sealed system (as always) drain down below the rad you wish to work on via a drain off point.
Make sure the rad you wish to work on is empty. Allow air into system while draining via the bleed valve or side cap. :D
the radiator is actually off. only the pipes and valves remain. sticking up from floor.
i was wondering if i could simply, replace the existing valves with new ones, without draining the system. or maybe a little water would come out.
thanks
