I have a dodgy (read: failed) Sunvic TLX 1206. Symptoms were that green "heat required" light would come on, but heating wouldn't. Then it deteriorated into no lights, until I killed the power, waited 30 secs and turned power back on, ad infinitum. Suspected the motorised valve at first, but this has operated perfectly when the Sunvic has decided to click the relay over.
Turned to this forum for help! What a relief!
I have now jumped the wires that went to the Sunvic, so I have permanently 'on' heating - not great, but at least we have heating.
Short version is I need to replace the Sunvic for something more reliable. I see elsewhere within the forum someone recommended either Honeywell or Salus.
My problem is, I have 4 wires that used to connect to the Sunvic, that I wouldn't know how to connect into any new device.
I obviously have the two wires that I jumpered which must (?) be the 'switch' pair, plus I have a pair for 'live' and 'neutral'.
The Sunvic was wired as follows (all wires are black but have numbers printed on them)
Wire 1 - Live
Wire 6 - Neutral
Wire 3 - On (terminal 3)
Wire 2 - Com (terminal 2
What recommendation(s) can anyone make as to what replacement I would do well to get, and then which wires would go where on the unit?
FWIW, I have a Viessmann boiler and an EPH T27 controller.
EDIT : Or could I go back to a wired solution? The cable that used to have an old analogue Honeywell is still in place - but only 2 wires? How would this connect up at the other (controller) end?
Wire 1 - Live
Wire 6 - Neutral
