Basically I can't see the proper way round fixing this and can only see two options. The zone valve needs replacing (leaking) and it is on a horizontal piece of pipe between two vertical runs in a "H" shape. (Don't know why builders didn't use a three way).
Anyway as the pipes feed in 5-8mm into the valve do I:
A: pull the pipes apart with brut strength with the possiblilty of bending cracking joins to remove old/insert new valve)?
B: cut off one side of the old valve install new section of pipe and use a sleeve and solder it in?
Thanks in advance.
Thanks in advance.
