Hi all, just a quick query.
I was discussing the consequences of reverse polarity in a shower with a work mate today. To set the scene, the mains "IN" at the 45A shower switch is connected correctly but the "Load" side is connected in reverse polarity.
When debating if/when/how the fault would be found during a PIR there were 2 sides.
In a nutshell I said it should, as you would not get an R1+R2 reading at the shower and would therefore need to be investigated and hopefully the fault would be found.
He said he takes his R1+R2 from the pull cord
and he would have got the reading from the "MAINS" and that the reverse connection would be found visually.
What would be the consequences of a reverse polarity in (ONLY) the shower, would it still function as it should?
If it was protected by RCBO with functional earth would this trip?
I presume if it was just a standard 30ma DP RCD then there would be no imbalance to detect?
