- Joined
- 27 Jan 2008
- Messages
- 27,540
- Reaction score
- 3,328
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It is common for a battery charger to have a relay which has to be energised by the battery so if connected wrong way around not damage will be done. Easy to get two clips mixed up.
However I have two battery chargers for my Nikon camera, neither original, one from car cig lighter the other from USB the latter will charge two batteries at the same time. When transferring pictures I did not switch off camera at end of transfer so the battery was run completely out.
On putting the battery on charge, nothing, no green or red LED but putting the other battery in the charger showed charger OK. So put the suspect battery in the car powered battery charger, then transferred back to USB charger and it charged OK.
It seems it the battery was simply too discharged to charge up again. But why, the battery can’t be connected wrong way around, just not physically possible.
