I am currently re plumbing the whole has, and it would be really easy to make the water, hot and cold, into a ring from the boiler, like an electric ring main.
I know this type of plumbing goes on in your brain, but i wondered if this would be a good idea in a house.
the logic being that if one bit of the ring gets blocked you have the other side to supplement it. Also if one tap is turned on the flow on the down stream taps is much less, but if its in a ring the down stream taps shouldnt be as affected as much.
i would only need about 1.5m of copper to make this happen.
Any thoughts??
Any thoughts??
