I have had the above boiler for about 8 months now and it was working fine initially. My friend decided to change the settings on the knobb from whatever the engineer had set it to to Hot water only. It worked fine, but when i tried to put it back to water and heating, my heat will not come on.
The hot water works fine but i am unable to get heat.
The only light is the first appliance operation light and it flashes green every couple of seconds.
There is no wall thermostat so i cannot change the temperature.
I am so confused can someone assist.
Thank you.
Louise
Thank you.
Louise
