Room thermostat
23 Aug 2009
Staffordshire
Hi all, hope some one could help me here I want to connect my room thermostat to my VAILLANT ECOTEC EXCLUSIVE 838 HE COMBI boiler this thermostat was used for my old vaillant boiler and worked fine only this time I won't be using any time clocks, I want to get it right in my head before I make an connections so here goes
TIA  8)
You shouldn't use a thermostat without a timer. Will waste energy.
Nevertheless, to answer your question;
Remove boiler link 3 to 4.
Thermostat 1 to boiler 3 (Live)
Thermostat 2 to boiler 4 (Live)
Thermostat 4 to boiler 5 (Neutral)
Sleeve live cables with brown marker, neutral cables with blue.
As your diagram says, the thermostat should be earthed.
can you not plug a compatible vaillant clock into the front facia of the boiler to give you correct htg control and then wire in your room thermostat :?:
much better off with a programmable stat such as the honeywell cm927, or even the Vaillant vrt360 specifically designed for this boiler.
Thanks a lot for your help guys appreciate what you say about a timer but we have heating on from when we get up till we go to bed anyway so never used the timer on the old boiler anyway.
regards :D
